Bedeutung des Aufklebers?
die Zwei
Beitrag von die Zwei »
...nach 10 Jahren bekomme ich von Nikon ein Neuse? ;)
Wer kennt die Bedeutung des Aufklebers?
Koerth
Beitrag von Koerth »
Hallo!
Herzlichen Glückwunsch zum 17-35/2,8! :birthday:
Tolle Linse, wie bereits beschrieben - aber DEN Aufkleber kenn ich nicht... auf meinem ist keiner drauf. :((
mc.manu
Beitrag von mc.manu »
auf meinem "Zehnfünfer" war auch so einer drauf, keine Ahnung...
compadre
Batterie2
Batterie2
Beitrag von compadre »
hat was mit entsorgung zu tun - glaube in china vorschrift. ken rockwell schrieb mal was drüber, hab aber genaueres vergessen, am besten dort nachlesen :???:
edit von KR-Seite:
Reader Chris Campbell suggests it's an RoHS symbol indicating that the product contains pollutants, such as lead, exceeding allowable standards under Chinese law. He suggests the 10 means that the pollutants will not leak out for at least 10 years under normal use. 10 years is the "Environmentally Friendly Use Period," or EFUP. These labels supposedly are required by Chinese law. Interesting - do the Chinese collect these for destruction after 10 years?
Yes! This is it! Reader Tim Devine points us to the answer, effective 01 March, 2007. It's a China RoHS symbol.
Reader Gary Caple clarifies that the 10 isn't how long the scary chemicals stay inside - the 10 means how many years of useful life the product has before it's trashed. Aha - now we know the service life of this lens! I wonder if new digital cameras will have a 2 inside the backwards circle, since digital cams are good for an average of two years before the big heave-ho. Lenses ought to last longer: I still use my Nikon manual focus lenses I bought in the 1980s.
Others propose 10 means how many years it takes the poisons to leach out. I don't know, and as the sources seem to confirm, no one really knows. It's all a Communist government trying to run things.
die Zwei
"ChinaRoHS ist die allgemein verwendete Bezeichnung für ein Umweltschutzgesetz der Volksrepublik China das ab dem 1. März 2007 in Kraft tritt. Ähnlich wie bei der EU-Richtlinie RoHS sollen giftige Stoffe in elektronischen Produkten verboten werden. Die betroffenen Stoffe und Grenzwerte sind identisch mit der EU RoHS, allerdings sind in der ChinaRoHS keine Ausnahmen zugelassen.
Diverse Details der Umsetzung sind bisher nicht bekannt, da China das Gesetz ausschließlich in Hochchinesisch zur Verfügung stellt existiert auch keine offizielle Übersetzung. Klar ist momentan nur, dass ab dem 1. März 2007 die Verbotsstoffe bei allen elektrischen und elektronischen Produkten die zum Verbleib in China vorgesehen sind deklariert werden müssen, Verbote werden voraussichtlich ab 2008 erlassen werden. Die Deklaration hat in Hochchinesisch zu erfolgen.
Vorerst ist nur eine Kennzeichnung von kompletten Geräten, bzw. solchen Baugruppen oder Bauteilen notwendig, die in den Handel gelangen. Dabei wird mit einem grünen Logo angegeben, dass das Produkt die verbotenen Stoffe nicht enthält. Andernfalls ist ein rotes oder oranges Logo mit einer ein- oder zweistelligen Zahl anzubringen, die angibt wie viele Jahre das Produkt bestimmungsgemäß verwendet werden kann bevor die Gefahr besteht, dass die enthaltenen, verbotenen Stoffe austreten und dabei eine Gefahr für Umwelt und Gesundheit darstellen (Environmentally friendly use period - EFUP).
Da die Bestimmung der EFUP ziemlich schwammig ist und eine uneinheitliche Angabe von verschiedenen Bauelementeherstellern zu erheblichen Problemen für Gerätehersteller führen würden, versuchen momentan die Wirtschaftsverbände alle Hersteller zu einer einheitlichen Angabe von 50 Jahren zu bewegen.
Im Gegensatz zur EU-Richtlinie RoHS verlangt die ChinaRoHS auch von der Verpackung eines Produktes die Einhaltung der Grenzwerte.
Zur Zeit stehen wenig frei verfügbare Informationen zur ChinaRoHS zur Verfügung, insbesondere im Internet. Die meisten Verbände machen die Informationen nur für Mitglieder zugänglich, da durch die fehlende offizielle Übersetzung die Beschaffung der Informationen mit entsprechenden Kosten verbunden ist."
siehe auch: http://www.zvei.org/index.php?id=3388
China RoHs ist schon korrekt! Die 10 bedeutet, dass erst nach zehn Jahren schädliche Stoffe aus dem Objektiv austreten können. Ich habe keine Ahnung welche das sein sollen. ;) Man muss halt angeben wie lange man das Austreten schädlicher Stoffe sicherstellt.
