Gegenlichtblende HK 22 = HK 26 AF-S 300
Heiner
Beitrag von Heiner »
Hi, kurze Frage:
Passt die Gegenlichtblende HK 26 des Nikkor 1:2,8 AF-S 300 Version II auch an die Version I ???
CU
Heiner
NPS
Scheint zu gehen:
Im Zusammenhang mit einem Review des AF-S VR200 gefunden:
The lens hood HK-31 is big and rather heavy, seems like Nikon is going back to the more heavy duty design rather than the lighter carbon fiber type. The hood is wider than normal, made to fit the tripod collar when stored in the reverse position. Older lens hood HK-19, HK-22, HK-26, and HK-30 will fit the lens if you prefer a slimmer profile and lighter weight (HK-19 is just as heavy as HK-31).
Link
