http://translate.google.com/translate?s ... emid%3D104KMZ to resume production of lenses" MC Mir-20M "," Helios 40-2 "and" Telezenitar 2.8 / 135. "
"The decision to resume production of lenses due to an increased demand for consumers, and this despite the fact that these lenses were produced for a long time and is only suitable for film cameras.
In this regard, the lenses have been developed and have bayonets for digital camera Canon and Nikon », - said the head of the marketing department of KMZ AM Ахмедов. Akhmedov.
Super wide angle lens "MC Mir-20M" - compact interchangeable lens with aperture of 3.5 / 20.The lens is equipped with a set of filters for high-quality images under various shooting conditions. The angle of view of 96 °, large depth of field allow to distinguish between the front, middle and background to accentuate different parts composite frame when shooting.
Good color, high light transmission and blikozaschischennost, excellent image quality across the entire field, the small size and weight, create favorable conditions for professional and amateur photography architectural ensembles, interior spaces, landscapes.
The cost of the lens: 7612 rubles.
Lens "Helios 40-2" has a high aperture ratio 1,5 / 85, and is designed for portraits, street photography, including low light, fast moving items that require small quantities of extracts, etc.
Feature is the use of multi-layer lens achromatic enlightenment, through which achieved a substantial increase in the transmission coefficient and the almost total destruction of the harmful scattered light, which lets you shoot even when in sight of the bright lights.
The cost of the lens: 8041 rubles.
. Interchangeable telephoto telephoto MS APO "Telezenitar-M 2,8 / 135" has a multi-layer anti-reflective coating applied to the lens, which increase the capabilities and reduce the scattering of light that provides particularly favorable contrast and sharpness, largely eliminates ghosting, flare and light spots even when shooting against the light.
The lens used in a special type of glass that will ensure its apochromatic correction, which improves image quality.
The cost of the lens: 10 999 rub.
oder
http://www.zenit-foto.ru/index.php?opti ... Itemid=104
KMZ ist hierzulande auch als Zenit bekannt.
